ArcGIS Online vs Portal - Download photo
  • May 25, 2023
  • 50 views
philippeb
Forum|alt.badge.img+22
Hey,
I'm trying to download photos from ArcGIS Portal. I enabled attachment and use the RasterReplacer. I get an error though.
fme_rejection_message (string: UTF-8): @GeometryFormat: Failed to read feature.  The error was: 'An error has occurred. Check the logfile above for details'
fme_rejection_code (string: UTF-8): INVALID_FEATURE_CANNOT_READ_BLOB
Everything works good on ArcGIS Online. Any idea why?
Thanks !
Best answer by philippeb
Okay I found the answer. https://community.safe.com/s/question/0D54Q00008D2NL1SAN/rasterreplacer-is-unable-to-recognize-attachments-from-esri-portal
philippeb
  • May 25, 2023
