Raster shifted 1 pixel
  • February 22, 2021
  • 29 views
nielsgerrits
Forum|alt.badge.img+64
I try to recreate a raster using FME which was originally produced using GlobalMapper. The input is a pointcloud, I use the NumericRasterizer and then send it to the GeoTIFF FeatureWriter. We visualize the result in ArcMap 10.7.
We also have contours generated. When I zoom in to a contour line it looks like the new raster is slightly shifted:
GlobalMapper
GlobalMapperRasterFME
FmeRasterI did some googling and tried different settings using the RasterCellOriginSetter but this does not seem to change anything. What can I do to fix this?
Update:
I can't reproduce this issue in QGIS so it looks like it is not correctly interpreted by ArcMap.
Best answer by nielsgerrits
This turned out to have an easy fix by switching "Write Esri-Compatible Coordinate System" to Yes...
2021-02-23_05h53_32I was so convinced it had to do with the cell origin I forgot to look further.
nielsgerrits
  • February 23, 2021
