Log file path issues?
  • November 17, 2023
  • 118 views
virtualcitymatt
Forum|alt.badge.img+47
Just looking to see if anyone has had similar issues?
I'm using FME 2023.1.1 and I've been having some strange issues with Log file paths. I has a workspace run on a separate machine with a workspace runner and the job filed to submit because it couldn't find the log path.
The log path was pointing to the original location on my machine. I took a look at the fmw in a text viewer and saw the path defined in full.
I reopened the workspace, moved a transformer and re-saved it. This fixed reset the log path back to "$(FME_MF_DIR)<workspace_name.log".
This has happened at least twice now and I'm not able to reproduce it. Just wondering if anyone has run into the same issue at all.
danpeek101
  • June 6, 2025
Hey there! I know you posted this a while back and didn’t get any responses, I’m running into the same issue using a WorkspaceRunner, did you ever figure out what was causing the problem?
virtualcitymatt
I didn’t - in the end I’ve just assumed that it was an FME version specific issue. I haven’t had the issue since I’ve started working mostly with FME 2024+
