Anyone know if there is a difference with NonEarth_Meter and XY-M when it comes to coordinate systems?
  • November 16, 2021
  • 104 views
virtualcitymatt
Forum|alt.badge.img+47
Sometimes when reading various files I get different behaviour for the coordinate system the FME chooses.
Sometimes I see 'NonEarth_Meter' while other times is something like XY-M. Seems to be somewhat random, however, it could be specific to the input format
Does anyone know if there is a difference of why both these definitions exist?
daveatsafe
Forum|alt.badge.img+20
  • November 22, 2021
Hi @virtualcitymatt​,
The FME coordinate system library contains a number of duplicate coordinate systems under different names. These are a result of updating CSMAP, but also having to support older workspaces the use the old names.
I think the reason you are getting different names returned by different writers is due to the developer setting a fallback coordinate system to the non-earth coordinate system name in use at the time.
Would you mind sending me the details on which readers are providing NonEarth_Meter and which are providing XY-M? I will create an enhancement request to have these harmonized.
