FeatureReader from file gdb to CSV
  • July 16, 2018
  • 35 views
Hello, I hope to back up all the data from my reader feature class into a CSV file, in case I would need to look up the data in the future. I used the FeatureReader with the parameter as shown in the picture, but the result CSV has each of my reader record increased exponentially. Not sure what happen in my case..
andreaatsafe
Forum|alt.badge.img+15
Hi @koala18,
It looks like the Reader Feature Type and the FeatureReader are reading the same feature class? If so, you may not need the FeatureReader, and you can just connect the Reader directly to the CSV writer.
- Andrea
  • July 16, 2018
Hi @koala18,
- Andrea
Hi Andrea, thanks for the comments. That is exactly what I need.
