Use SAML account in FME Flow REST API
  • July 21, 2025
  • 55 views
fei2000
I am new to FME Flow. My organization had setup a FME Flow 2024.2 and integrated SAML for user login.
I am just wondering whether I could use SAML account in FME Flow REST API and how to use it to generate a token for further REST API requests. Furthermore, is the generated token secure enough to prevent accessing other users’ resources, workspaces and data connections.
Thanks in advance,
Henry from TfNSW
Best answer by hkingsbury
For SAML users, I would think that they need to first login to the UI, then generate a token via https://<fmeflowurl>fmeserver/tokens/api.
@nielsgerrits ​@david_r Have either of you looked into this before?
hkingsbury
Forum|alt.badge.img+67
  • July 21, 2025
Hi Henry
The SAML user will be able to use the REST API.
Token creation is based on the role the user has. For example, the user is part of a role that only has access to a repository called 'Transport'. When they go to create a REST API Token, they will only be able to create a token that has access to 'Transport'.
You can't control workspace sharing at the workspace level, but you can individually share database and web connections.
When a user uploads a Database or Web Connection, it can only be seen by that user, or an Admin, unless specifically shared to another user or role.
fei2000
  • July 22, 2025
Thanks hkingsbury for the clarification of the token security and its use case.
Could you please detail how to create a REST API token by the SAML user? I had tried both REST API V3 and V4 to generate the token, and only the system user account could generate the token via REST API, but failed by the SAML users.
hkingsbury
  • July 22, 2025
fei2000
  • July 22, 2025
Thanks hkingsbury, I could login to the FME Flow with SAML account and generate an api token. Then I could use this token in https://[fmeflowserver]/fmerest/v3/[action]?fmetoken= for further REST API actions.
