Problem with Azure AD guest users in FME authentication service
  • Nov 1, 2022 2:00 PM UTC
  • 101 views
fjanson
I have set up integration between FME Server (v2021.2.6) and Azure AD where I am able to import users from AAD and native AAD users are able to single sign in using microsoft. The problem is that Guest users in AAD are not able to single sign in using Microsoft login. It seems that the FME server logon instead tries to authenticate through the users home-tenant. Does anyone have experience with this setup?
danminneyatsaf
Forum|alt.badge.img+13
Hi @fjanson​, unfortunately Azure AD Guest Users authentication in FME Server is not supported at the moment. If you are interested in added support for this in FME Server, I suggest submitting an idea on our Ideas page here where you can gather votes and potentially get this turned into a future enhancement!
fjanson
  • Nov 2, 2022 7:42 AM UTC
Hi @danminneyatsaf​  , thanks for your reply. I will submit this as an idea.
