java version, Adobe Reader/Writer, Adobe flash
jvdkleijn_ehv
We have installed a FME Server 2020.1.1.1 with a 2020.2.5.1 engine.
Our security department has te following questions :
•            Are there plans to upgrade the Java version to the newest version?
•            Is the installation of Adobe Reader/Writer a part of the global installation?
•            Is the installation of Adobe Flash a part of the global installation?
Hopefully somebodey can answer the questions.
with kind regards,
John van der Kleijn
Functional manager GIS
Municipality Eindhoven
kailinatsafe
Forum|alt.badge.img+22
Hello @jvdkleijn_ehv​ , thanks for posting! Is this concerning FME Server or FME Engine (if Windows)? Also, for Question #1, do you mean upgrade to latest Java 8 version or is this a question of when we are moving to version 11? Best, Kailin.
jvdkleijn_ehv
  • February 3, 2022
Dear kailin,
Thank's for your reply.
about your questions:
  • It concerns both.
  • I am not known with Java versions. What is the current version?
  • Are there plans to upgrade to a higher Java version. When this is te case, which version?
with kind regards,
John van der Kleijn
kailinatsafe
jvdkleijn_ehv wrote:
Dear kailin,
  • It concerns both.
with kind regards,
John van der Kleijn
Hello @jvdkleijn_ehv​ , I've confirmed with development that Desktop/Engine (Windows) and Server currently share the same version of Java 8. FME Server is planning to attempt the upgrade to Java 11 or 17 for FME Server 2023.0 (FMESERVER-17624), but will likely upgrade to a newer/the newest version of Java 8 for FME Server 2022.1 or 2022.2. Hope this helps, Kailin.
jvdkleijn_ehv
  • February 8, 2022
Dear Kailin,
As an addition we have the following question.
Can you tell us which log4j version is going to be used in the FME server 2022.1
with kind regards,
John van der Kleijn
daraghatsafe
Dear Kailin,
with kind regards,
John van der Kleijn
Hi @jvdkleijn_ehv​
I am not sure of the exact version but log4j to version 2.17.1 in FME 2021.2.2 and this applies for newer builds also. Please see this article for more info.
Hope this helps, Daragh
