I would like to use the token service to generate a token for the user logged in on Windows, so I can use this token in my webapplication. How do I do this?
  • Feb 9, 2017 3:29 PM UTC
  • 5 replies
  • 115 views
  • Feb 9, 2017 3:36 PM UTC
You can use the FME Server REST API to request a token, either directly or through the FMEServer javascript library. Some starting points:
  • Feb 10, 2017 7:03 AM UTC
@david_r I know those pages, but I don't want to pass the user-id and password in the URL. That's a security issue. I also don't want the user to supply his username or password. I want to use Single-Sign-On to request a token, so the user doesn't have to enter his credentials anywhere.
We have FME Server configured for Single-Sign-On, so a user is automatically authenticated with his Windows credentials. The interface of FME server is not user friendly enough for non technical persons, so we want to integrate a webpage into our intranet where a user can run workspaces.
fmelizard
Forum|alt.badge.img+22
  • Feb 10, 2017 10:00 PM UTC
Hi Martin, based on what you've described, I believe you are looking for this enhancement:
https://knowledge.safe.com/idea/23531/add-support-for-integrated-windows-authentication.html
Please do review and vote and comment if it is applicable.
fmelizard
  • Feb 13, 2017 7:06 AM UTC
Thanks Aaron, that's exactly what I was looking for. I voted, now let's hope Safe will address this issue.
