How to generate Token in FME Server 2016
Hi there,
I can generate Token from FME Server2017 using C#, tested with postman, see attached image, but when I try to use same method from FME Server2016, it gives me error: Both user ID and password need to be specified for viewing/generating token. So what's the correct way to generate Token in FME Server2016.1 using postman or C#. Thank you very much.
Best answer by larry
This is how I do it on all versions:
http://fmeserver/fmetoken/generate?user=usr&password;=pwd&expiration;=1&timeunit;=day
Just tested on 2015.1 and 2017.1.
I don't have a 2016 at hand to test right now.
Using a form post does not seem to work on 2015.1, I have the same error message as you have.
  • December 8, 2017
nielsgerrits
Forum|alt.badge.img+54
I can confirm this works in server 2016.
  • December 8, 2017
resolve this issue, above "GET"method works, "POST" also works when specify body to x-www-form-urlencoded
