how to generate token id from postman.json
  • June 28, 2019
  • 34 views
nag
Hello,
Is there anyway to generate token id from postman?
Thanks.
Best answer by richardatsafe
Hi @nagendrudus,
You can generate tokens or list tokens from with a call using our REST API. You can open the rest API on your FME Server installation directly and test it out if you wish.
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#
richardatsafe
Forum|alt.badge.img+10
  • July 3, 2019
Hi @nagendrudus,
