How can i upload license file via API?
  • May 3, 2021
  • 21 views
I´m executin this command to upload the FME license:
curl -X POST "https://localhost:443/licensing/license?filetype=fmelic" -H "Authorization: fmetoken token=****" -H "Content-type: application/octet-stream" -H "Accept: application/json" --data "@fme_license.fmelic"
But i got this error:
<!doctype html><html lang="en"><head><title>HTTP Status 404 – Not Found</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 404 – Not Found</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Message</b> The requested resource [&#47;licensing&#47;license] is not available</p><p><b>Description</b> The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.</p><hr class="line" /><h3>Apache Tomcat/9.0.44</h3></body></html>Done..
Best answer by hollyatsafe
Hi @misazab95​ ,
Your URL is currently missing the reference to the REST service, please update your URL to:
https://localhost:443/fmerest/v3/licensing/license?filetype=fmelic
To help set up REST API calls I'd recommend opening the REST API documentation directly from your FME Server by selecting the 'Help' icon in the top right corner. Then under the endpoint you'd like to use you'll find an example of the request URL.
2021-05-03_13-01-54
  • May 3, 2021
Hi @misazab95​ ,
2021-05-03_13-01-54
