Hi! Have anybody succeeded in connecting the Mapillary API v4 with FME workbench? I get stuck on an internal server error when i use https://localhost/ as redirect URL in the OAuth 2.0 webservice authentification.
  • Sep 10, 2021 1:38 PM UTC
  • 5 replies
  • 153 views
henrikstagnell
Forum|alt.badge.img+3
jovitaatsafe
Forum|alt.badge.img+11
Hi @henrikstagnell​, have you already had a look at this article on Web Connections and FME? There's a section that describes OAuth 2.0 connections that might be helpful to configuring your own connection
rahulsharma
Forum|alt.badge.img+12
Hi @henrikstagnell​ as @jovitaatsafe​ mentioned. The article is a good starting point.
For most cases, leaving the default Redirect URI values works for FME Desktop ("urn:ietf:wg:oauth:2.0:oob").
Or else you can try using 'http://localhost' as well, if HTTPS is required, please ensure that the certificate is present on the FME Desktop machine.
Have you configured the app correctly on the Mapillary API?
I would advise adding all the variations of redirect URI in the application(Mapillary.com).
FYI - The OAuth2.0 template is configured to have a Refresh token workflow.
rahulsharma
Hi @henrikstagnell​
I have done a quick test, I am not familiar with the API myself but I was able to try it using the instructions.
After creating the OAuth2.0 services following the developer API documentation, I was able to set up a web service and able to generate a token see a short demo here
Here is the configuration and URL that I used for this test.Mapillary_Oauth
malikfadi
Participant
  • Participant
  • Nov 25, 2021 5:06 PM UTC
I am having an error when clicking at authorize.
Can anyone help me out, where I am making a mistake?? I am trying to fetch Traffic Signal features...!
 Thanks.
Mapillary Error
joakimoy
Participant
  • Participant
  • Oct 26, 2022 8:03 AM UTC
 Thanks.
Mapillary Error
I managed to make this work by adding Authorization under HTTP Header for Retrieve Token Parameters:
image.pngimage
