fmedatadownload and security best practice
  • May 21, 2025 10:26 AM UTC
  • 152 views
gkvoelkl
Hello,
I am a newbie and want to use fmedownload api in our new webpage.
what is the best way to integrate security?
at the moment I would call the the get token service with user and password to get a temporary token.
Then I would use this token and call fmedownload.
Is that the best way? Will the token service be available in the future?
thanks
best regards Gerhard
alexbiz
Forum|alt.badge.img+35
  • May 21, 2025 12:39 PM UTC
Hey Gerhard,
Have you had a chance to check out webhooks in FME Flow?
You can find more info here: Working with FME and Webhooks
It might be helpful to create a webhook through the FME Flow web UI. This will generate a dedicated token with limited permissions to run your workspace.
gkvoelkl
  • May 26, 2025 8:45 AM UTC
A web side wants to use my fme Flow with api and JavaScript. What is the best and secure way to do this?
I am looking for some javascript examples.
carlw
Forum|alt.badge.img+11
  • May 30, 2025 11:04 PM UTC
Hi Gerhard,
You’re on the right track! Important to note that by default, the token will expire within 1 hour unless configured otherwise. There’s a popular article that covers tokens / auth in detail here: Authorization in the FME Server REST API | Token Management
I’d also recommend exploring the article shared by ​@alexbizΒ - this sounds like it would be a great situation forΒ implementing a webhook!
