Directory and File Pathnames Reader - - warning - No files found in folder '____' using glob pattern '**/*' with glob filter 'ANY'. No features will be read
  • Oct 28, 2020 8:26 PM UTC
  • 148 views
lobsterboy
I am using the Directory and File Pathnames reader and I receive the warning.
No files found in folder '____' using glob pattern '**/*' with glob filter 'ANY'. No features will be read.
However, there are clearly folders in this location
To ensure it wasn't security issues, I tested the Adobe Geospatial PDF reader to read a PDF within the folder and it can read the contents perfectly.
Does anyone have any idea why I can't read any directories or pathnames?
daraghatsafe
Hi @lobsterboy​ , is Recurse into Subfolder set to Yes?
If you remove the glob patter **/*, and run the reader what happens?
Thanks, Daragh
