Upgraded from FME Desktop 2022.2 to FME Desktop 2025.1 (Build 25609)
In FME 2022.2, I had a FeatureReader reading to a FeatureService URL with no issues. Perfectly was able to read it and extract its spatial content and attributes. Upgraded to FME Desktop 2025.1 and it no longer works. Could this be like an internal firewall blocking access to this or is it the way FME 2025 handles SSL certificates? If so, how can I remedy this?
Any insight is much appreciated.
SAMPLE Workbench
I have the latest package installed
Error message:
ArcGIS Feature Service Reader: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='services.arcgis.com', port=443): Max retries exceeded with url: /mMUesHYPkXjaFGfS/arcgis/rest/services/ROLL_ENTRY/FeatureServer?f=json (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Basic Constraints of CA cert not marked critical (_ssl.c:1028)')))'
Python Exception <FMEException>: FMEException: 926856: ArcGIS Feature Service Reader: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was 'HTTPSConnectionPool(host='services.arcgis.com', port=443): Max retries exceeded with url: /mMUesHYPkXjaFGfS/arcgis/rest/services/ROLL_ENTRY/FeatureServer?f=json (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Basic Constraints of CA cert not marked critical (_ssl.c:1028)')))'
Failed to obtain any schemas from reader 'ARCGISFEATURES' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
I even have the Rejected Feature Handling to Continue Translation.
FeatureReader setup which worked perfectly fine in FME 2022.2 but not in FME 2025.1
I’ve tried the following format but its configuration for a web connection is not needed, since the REST feature service URL I’m accessing does not require a username nor password https://services.arcgis.com/mMUesHYPkXjaFGfS/arcgis/rest/services/ROLL_ENTRY/FeatureServer
