Good morning,
I have a folder in an S3 bucket that contains a folder for each day of the year and each of those folders contain about 24 files. Since I need to download the data in order to process it, is there a way to only download the folders that contain the word “2025”? I have not been able to format a wildcard that works for a folder. I could also potentially use a wildcard to select the files, if there is a way to do that.
Thank you,
Peter
