Cannot find the Create AR app in FME Flow
smjie
So in one of the tutorial for creating AR, the screenshot of FME Flow has the Create AR App option in Flow Apps. But I opened my FME Flow 2025.02 version, it only appears these options without Create AR App:
Is anyone having the same issue? Is there anything I did wrong?
Thank you so much for the help.
Best answer by dylan.at.safe
Hi ​@smjie,
Under the requirements section for this article, you should see the following:
  • FME Form 2025.1+
  • FME Flow 2025.1+
Since AR apps are still in beta, you'll need to upgrade to the beta version (2025.1) to use them. You can download the latest version on our downloads page: https://fme.safe.com/downloads/.
dylan.at.safe
Forum|alt.badge.img+7
Hi ​@smjie,
  • FME Form 2025.1+
  • FME Flow 2025.1+
crutledge
Forum|alt.badge.img+33
  • June 2, 2025
Hi ​@dylan.at.safe Hey do we have a release date on 2025.1? I know…but I had to ask. :D
dylan.at.safe
Hi ​@crutledge
Unfortunately, I can't provide an exact date for when 2025.1 will exit beta, but .1 releases typically roll out in early summer, likely around July. Although it’s always possible for this timeframe to change.
smjie
  • June 9, 2025
dylan.at.safe wrote:
Hi ​@crutledge
Thanks! Is there any other way to create an AR model that can be tested in phone or ipad now?
dylan.at.safe
Hi ​@smjie
You can download the beta release of FME Flow and FME Form (2025.1) from our downloads page to test AR applications. This version is available now and is currently the only way to use AR Apps. To access it, click the dropdown next to the current version and select 2025.1. Please note that this is a beta version and should not be used in production environments.
