Missing output files when publishing to FME Server (works locally and in old workbench on server )
fmegrinder
I’m running into an issue with FME Workbench 2021. When I run the workspace locally, all expected files are generated correctly. The same workspace also works when published to our older FME Server (same version, 2021.0).
However, after publishing it to a new FME Server environment (also 2021.0), some of the output files are missing. No errors are reported in the log, but certain files simply don't get written. The log even says they have created the files.
Nothing has changed in terms of file paths or logic – they still use dynamic paths (e.g., FME_SHAREDRESOURCE_TEMP). The only major change is that we replaced FeatureReader with HTTPCaller to avoid a bug with esri_OID in high availability setups.
I’m running the exakt same job but still I get this issue.
I’ve already:
Verified that the paths are correct
Checked resource locations
Tried republishing and updating the “download data” edit.
Still, the problem remains in the new server setup.
What could be causing this?
david_r
  • May 28, 2025
Could it be that the new server is low on disk space and that the FME Flow cleanup task is in aggressive clean up mode?
https://support.safe.com/hc/en-us/articles/25407763387277-FME-Flow-Troubleshooting-Cleanup-Tasks
fmegrinder
  • May 28, 2025
Thanks for the tip ​@david_r but that should not be the issue.
The old workspace that does the same thing works 100% of the times.
But the new one that I’ve done some alternations with does not include the files(most often pictures).
Forum|alt.badge.img+55
  • May 29, 2025
One debugging step i’d consider would be to write to a defined location such as c:\temp. This will help narrow down if it is a ‘writing the file’ issue or a ‘location where the file is written’ issue
fmegrinder
  • May 30, 2025
Thanks for the tip, @hkingsbury.
I’ve tried this now, but unfortunately it doesn’t work.
I think it's a strange bug in the Workbench.
It works when I activate the “old path” inside the embedded transformer — even though that path doesn’t lead to any output port.
If the part is active, everything works perfectly.
But if I deactivate it, it stops working.
So it seems like some kind of bug.
Any suggestions on how to solve it?
  • June 4, 2025
An approach that i’m not sure if it will work, but worth trying…..
Open a brand new, fresh workspace and copy the entire contents of the existing process into the new one. Save, publish to Flow and test
virtualcitymatt
Forum|alt.badge.img+36
Are you using the data download service? Are the files missing from the ZIP?
I’ve seen some situations where is seems like the zip gets created before all data are actually available to be zipped.
Perhaps enabling this “old path” changes the order in which things are processed.
fmegrinder
  • June 16, 2025
Yes, we're using the download service, and it's always the same files that are missing — although I do receive the vector files. The workspace consists of two different processes: one that generates GeoJSON files and another that creates background maps.
I think you're onto something. When I tried removing the old path entirely instead of just disabling it, I got one image (it should have been four). So it's almost like the workspace misinterprets the process as completed even though it's not actually done.
virtualcitymatt
You might be able to see clues of it in the log. You can try putting down a feature holder before the writer, that might help.
There is also the option in the HTTPCaller to reduce the number of parallel requests. If you put this down to 1 (default is 25) then it may help.
If you're able to somehow see this in the log or are able to share this with Safe then you should try and report it to them.
