How do I relate the version number of a Transformer to the Version number of the software?
nicholas
Forum|alt.badge.img+13
Hi All,
I have set up my tool tip to tell me the version number of a particular Transformer in my workbench.
Is there a way of relating the version number of a Transformer to the version number of my software?
Can I find out which version of the software that a particular Transformer has an upgrade?
For any particular software version, is there a list of the version numbers of the Transformers?
Nick
desiree_at_safe
Forum|alt.badge.img+12
Hi ​@nicholas!
I'm still looking into your post, but so far this sounds like an interesting and possibly really helpful functionality!
Am I right in thinking it's for long-term maintenance of workspaces? I'd love to understand your needs a bit better as well:
1. When you mention "relating the version number of a Transformer to the version number of my software," could you clarify what this relationship would look like for you? Are you hoping for a mapping system, documentation reference, or something else?
2. By "software version," are you referring to the main FME build number (like 2025.0, 2024.3.5) or something more specific?
3. How would you ideally like to view and use this information? Would you prefer it integrated into the workbench interface, as separate documentation, or in some other format?
4. Could you share a bit about your use case? Understanding how you're planning to use this version relationship information might help uncover the best approach. I think your question about tracking transformer version changes across FME releases could be quite helpful for many users
I'm looking forward to learning more about this topic with you. 🙂
desiree_at_safe
Following up on this, currently we don't have a direct way to relate transformer version numbers to specific software versions externally.
The Change Log, which you can access from the software Downloads page, is the closest resource we have right now:
AD_4nXcxsHKNjsVcuOUlqROU8nzL0h899ZH12-yNl3b3RE1fm_CJFeieZqxfsh6Kyw1IE4GXpGdWkf6-uHddw0DgXyf8v84SnaYom4roiy5ce6ya2QLLihZr1rU9zD0L4FOhq4aW5Qbm3g?key=qBlL3YI8ZpRjztqhfdasPw
AD_4nXcUFkRDKiXYXS1tXgYQEu5oMQ3cU8MQk6HDvoMFv03pnCuAUwrT5xTlg-1MjlUI2vChkiS0C5hTqfTGFyydE8kYtT_FL6Ei7DLRX5zPCSThbEc7acfEXwqx4q06NKky65xJ5WHJLQ?key=qBlL3YI8ZpRjztqhfdasPw
You can search for specific transformers to see what changes were made and in which build, though it doesn't always list transformer version numbers.
This sort of resource could be really valuable for users, and it’s a great idea!
I would recommend posting it in the Community Ideas Forum
Let me know if you have any other questions!
