PDF Page Formatter. How to avoid Manual X/Y Adjustments in PDF page formatter
  • April 17, 2025
  • 43 views
gogopotter90
Forum|alt.badge.img+13
Hello ,
Is it possible to control the position of Upper left x and Upper left  y in a PDF formatter by setting their values in an attribute beforehand, so that the PDF formatter reads and uses them directly?
I don’t want to keep adjusting the x and y positions directly inside the PDF page formatter every time I find that the output is not properly aligned.
Do you have any tricks or suggestions to help me arrange my PDF layout more quickly?
It takes a long time to design the PDF layout .
Thanks in advance .
AliAtSafe
Forum|alt.badge.img+22
  • April 21, 2025
Hello ​@gogopotter90.
Thanks for posting to the community. We noticed you have made another thread here: How to avoid Manual X/Y Adjustments in PDF page formatter. We will take a look over there for you.
Thanks!
