Field Type - Time only
adnanyazdani
Hi Experts
I would like to suggestion and Guidance
Does FME Form has Time as field type
I’m using FME 2024
takashi
  • April 10, 2025
Hi ​@adnanyazdani ,
Supported data types are depending on data format. If "time" type doesn't appear in the drop down list, you can think that the format doesn't support the type.
adnanyazdani
  • April 10, 2025
@takashi
Thanks for the reply
Actually i received the information of time in text field and our schema is time only..
Here comes the challenge because i have very huge time.
Any Suggestion
crutledge
Forum|alt.badge.img+32
  • April 10, 2025
Hi ​@adnanyazdani That depends on the file format of the writer you are using.
I am just guessing here but it looks to me like you are trying to write in an ESRI File Geodatabase?
Are you using the File GDB Open API writer? Then I do not think there is an option as time only is a newer field type for ESRI and GDBs
Below is a pic from a File Geodatabase Writer (not the Open API version) so time is an option. Again this all depends on the type of file you are trying to write. Hope this helps.
takashi
  • April 10, 2025
@adnanyazdani
If the destination format doesn't support "time" type, it's a general alternative to treat a time value as a text. Is there any problem if time values are stored in a text type field of the destination dataset?
adnanyazdani
  • April 10, 2025
yes , you were right
I was using ESRI Open API because I was getting an error
How can i resolve this error when i use Esri Geodatabase (File Geodb) transformer
Thanks Again
crutledge
  • April 10, 2025
Thanks Again
Well then…. Do you have access to the full File Geodatabase Writer in FME? You will have to have an active ESRI License to use this and that is a licensing thing not a software capability thing.
If you are forced to use the ESRI Open API then I….that might be a problem. I would go with ​@takashi ‘s suggestion of treating the data as text might work for you. You may have to play around with the EXACT format that ESRI is expecting in a time field though. Hope that helps! Good luck!
Convert string or numeric time values into date format—ArcGIS Pro | Documentation
Supported field formats—ArcGIS Pro | Documentation
Hope that helps!
