Find point where lines are parallel
katt
Forum|alt.badge.img+12
I have two lines that are starting from the same point (blue point). I would like to calculate the geometry of the points where the lines start to run in parallel (approx. where the green points are). How can I do it in FME ?
takashi
Hi ​@katt ,
I think a possible approach as in:
  1. Chopper (Mode: By Vertex, Maximum Vertices: 2) : Split the input lines into individual line segments.
  2. 2DVectorCalculator from FME Hub: Calculate x, y components (e.g. _vx, _vy) of 2D vector for each segment. The components specify the direction of each segment.
  3. AttributeRounder : Round the components with an appropreate precision.
  4. VertexRemover : Transform each segment to its first vertex point.
  5. NeighborFinder : Select point where there is same direction point within a certain distance (maximum distance between parallel lines).
    • Group By: _vx, _vy
    • Transformer Mode/Input: Candidate Only
    • Number of Neibours to Fine: 1
    • Maximum Distance: <a certain distance>
danilo_fme
Forum|alt.badge.img+42
takashi wrote:
Hi ​@katt ,
Excellent ​@takashi
