How to iterate though a list of strings read from an Excel doc and attribute filters
howeitzor
I have a workbench that creates a table based on a number of joins that are on occasion, filtered on an attribute. Instead of manually entering the attribute values, I’d to read a list of attributes from, say, an Excel doc e.g. NSG001, NSO001, TES001 so I don’t have lots of duplicated transformers. How do I iterate through a list of values and plug them into FeatureJoiners without duplicating lots of stuff.
Best answer by crutledge
Hi ​@howeitzor I would suggest creating a new workbench using a workspace runner to call a modified version of this workbench. In the new workbench you will read the excel “list” and the workspace runner will call the workbench to run once for each value in the excel list.
Test Batch Processing Method 3: Using the WorkspaceRunner – FME Support Center
Hope that helps!
crutledge
Forum|alt.badge.img+31
  • March 24, 2025
Hope that helps!
howeitzor
  • March 24, 2025
Hope that helps!
Thanks ​@crutledge. This looks promising. I’ve setup the workspace runner. Assuming I create a user param in the joining workspace then set it to be the read name from the Excel doc, is it possible to then use that in the joining workspace in an attribute filter? I can’t seem to use it.
EDIT: I replaced the AttributeFilter with a TestFilter and looks promising.
crutledge
  • March 24, 2025
Hi ​@howeitzor
The way I had understood it was the excel was a “list of things to loop through”. In the past I have read in an excel sheet to provide a list of variables to pass as parameters to the second “child” workspace. In the pic below I read in an excel sheet with paths and imagery index names. Then those two get passed to the workspace runner. For each line in the spreadsheet the second workbench is called and does it’s thing.
Does that help? Did I understand correctly?
howeitzor
  • March 24, 2025
crutledge wrote:
Hi ​@howeitzor
Exactly. My workspace runner just finished and everything looks good. Appreciate the help, thanks again.
