The error message in your FME Flow Server job indicates that FME is unable to connect to the File Geodatabase at \\vmbldtstweu001\F$\TestFME\TestCheckout_ERW.gdb.
  • March 20, 2025
  • 15 views
durgam.balaraju
Observer
While running a job on FME Flow 2024 Server, the following error occurred:
"Unable to connect to the File Geodatabase located at '\vmbltstweu001\FS\TestFME\TestCheckout_ERW.gdb'. Please verify that the correct file path is specified and that the Geodatabase is not saved in a newer version of ArcGIS than the one installed on the server. The error code from ArcObjects is '-2147024891'."
Could anyone please help me on that
mattmatsafe
Forum|alt.badge.img+13
  • March 21, 2025
Hi ​@durgam.balaraju, is the .gdb present when you browse to that location outside of FME Flow? To make sure it’s not an access issue, have you tried uploading the .gdb to the Data folder in FME Flow Resources and accessing it from there? For the FME Flow Engines to access files on a system share, it must be running under a service account with access to that location.
If it’s not an access issue, it could be an issue with the .gdb version itself, as indicated in the error returned by Esri. Perhaps it was created in a version of ArcGIS Pro that is newer than the version of ArcGIS Server FME Flow is using.
