FeatureMerger and FeatureJoiner do not match visually identical values
tb09114
Forum|alt.badge.img+23
I need to use FeatureMerger or FeatureJoiner based on two varchar(200) attributes.
Visually those values do match. No white spaces trailing anywhere, the strings are the same, yet neither FeatureMerger nor FeatureJoiner are able to combine the data.
settings for FeatureJoiner
As an example from the the Feature Information pane
right attribute to join on
left attribute to join on
The join/merge is supposed to happen within a custom transformer, but I also tried it in the main workflow, where I received the same results.
FeatureMerger is in version 21, and
FeatureJoiner is in version 1001.
Any suggestion on how I can identify the culprit and get these features to join/merge?
redgeographics
Forum|alt.badge.img+49
They look the same indeed, hmmm…
Could it be a difference in encoding perhaps? Wild guess but you never know…
In the FeatureMerger you can access the Text Editor and use functions, if you try @Uppercase() with both of them, maybe that’ll work.
Forum|alt.badge.img+38
  • March 12, 2025
Have you checked for non-printing characters?
Zero width spaces are often the culprit in these sorts of scenarios in my experience
  • March 12, 2025
Regular expression for a zero width space
[\x{200B}]
Another thing to try is using a TextEncoder and set to URL (Percent Encoding) to look at whether the encoded text still looks the same
Two things that look the same, aren’t actually the same
tb09114
  • March 12, 2025
Thank you ​@redgeographics I did try the Uppercase method but sadly that didn’t change the results.
@ebygomm since your proposed methods included the encoding issue Hans suggested before I went with the TextEncoder set to URL (PercentEncoding)… nothing 😣. Also the search for zero width spaces returned no occurence of such things.
  • March 12, 2025
If you test for that value on both supplier and requestor do you get features passing?
tb09114
  • March 12, 2025
Yes, I tested both the supplier and the requestor but the FeatureMerger was not capable to merge them.
But, there is something fishy here. When I use the ConvertEncoding string function in the text editor and convert the seemingly identical values to fme-binary then value for bassin are:
Supplier: 62617373696E
Requestor: 666D655F666561747572655F74797065
  • March 12, 2025
Your requestor is the value fme_feature_type based on that, not the value bassin
tb09114
  • March 12, 2025
@ebygomm you are so right! I corrected the missing value reference in the string function and now I can see the value for bassin is on both occations (supplier/requestor): 62617373696E
However, the FeatureMerger still cannot make a single match.
