Line disappears after using AreaBuilder
arash_hokm
Hi everyone,
I'm using the AreaBuilder transformer in FME to create polygons from line features. However, I've noticed that some lines disappear after processing. It seems like the AreaBuilder ignores or removes them in certain cases.The lines are neither in the Area nor in Incomplete nor in Rejected.
The lines that have disappeared are marked in yellow.
after Areabuilder
before Areabuilder
What could be the reason for this? Are there any settings or common issues that might cause lines to disappear?
Thanks in advance for your help!
Best answer by j.botterill
Hi there, in order to understand the input polygon better, can you select one feature and show the “feature information”. Is the geometry an fme_polygon? can you run a GeometryValidator over all features with Set to issues to Detect = All
Only send the passed feature onto the AreaBuilder
j.botterill
Forum|alt.badge.img+40
  • March 7, 2025
arash_hokm
  • March 10, 2025
@j.botterill Thank you very much. It worked.
