How to Establish a Connection Between FME Server and UiPath to Automate Data Extraction ?
  • February 8, 2025
  • 0 replies
  • 22 views
jokerfme
Hello ,
I would like to automate data extraction from FME Server using UiPath.
Currently, I manually select each city from FME Server and extract an Excel file containing the required data for each city ,then i place the extracted Excel file in a specific folder for the UiPath to process and perform tasks using the data , UiPath reads the IDs from the Excel file for processing.
I'm wondering if it's possible to establish a connection directly between UiPath and FME Server, perhaps using a REST API, to directly retrieve the data and work on it without manually downloading each Excel file.
Is this possible, and how can it be implemented?
Thank you in advance!
Be the first to reply!
