Location of FLOW backup
  • January 25, 2025
  • 32 views
louielou1234
We are trying to update our on-prem FLOW (from version 2023.2) and I have successfully created the backup but am unable to determine the location of where the file was saved to.  The FLOW interface does not provide any clues as it does not indicate the target directoy (please see attached screen grab).  And doing a seach on my C and D drives with keyword ‘.fsconfig’ yelds no results. Where does the backup file get saved to?  Thanks!
Best answer by hkingsbury
If you select download, it will use generate a download link for your browser to download to your default downloads location.
If your instance is particularity large, then it might take a while to generate the backup.In that case, it would be better to save it to a resource location. You can then download the backup from that resource once it is generated.
https://docs.safe.com/fme/html/FME-Flow/WebUI/Backing-Up-FME-Flow-Config.htm
  • January 26, 2025
