Feature Reader Where Clause
  • January 16, 2025
  • 46 views
ingalla
Forum|alt.badge.img+10
Hello
I have set up a feature reader, reading a geopackage and have also set up a user parameter requesting the GSS code from the user to find.
When i add “gsscode” = $(LOCALAUTHORITY) nothing is exited via the reader, however, if i remove the where clause from the reader and add a tester with gsscode = $(LOCALAUTHORITY) everything works as expected.
Please see images below, but any ideas what is wrong.  I dont mind having a tester, but would just like to remove it and use the WHERE Clause..
Regards
Andy
Feature Reader
Parameter
Tester
Best answer by liamfez
Try adding quotation marks around the parameter in the where clause, like this:
“gsscode” = “$(LOCALAUTHORITY)“
liamfez
Forum|alt.badge.img+35
  • January 16, 2025
ingalla
  • January 16, 2025
Thanks very much, worked perfect…
Safe - do you need to update the documentation for the feature reader to specify the double quotes…..
