How to Create a Rectangle Using Top-Right and Bottom-Left Coordinates in FME?
  • October 30, 2024
  • 175 views
arash_hokm
Hello FME Community,
I have point data with attributes for the X and Y coordinates of the top-right and bottom-left corners (e.g., X_TopRight, Y_TopRight, X_BottomLeft, Y_BottomLeft). I would like to create a rectangle based on these two corner points.
Could anyone suggest the best approach or transformers to use in FME to accomplish this?
Thanks for your help!
Best answer by geomancer
Take a look at the 2DBoxReplacer 😉
geomancer
Forum|alt.badge.img+48
  • October 30, 2024
arash_hokm
  • October 30, 2024
@geomancer Thank you
geomancer
  • October 30, 2024
You're welcome!
Recently I struggled with the same question. I thought up a few difficult solutions before I found the easy solution: 2DBoxReplacer.
