How to set FME Flow Schedule (under Automations) to run quarterly? I’ve tried the following CRON expressions:
0 0 1 */3 *
and
0 0 1 3,6,9,12 *
FME throws an error for both of these expressions.
Is there a known work around?
Note: I do not want to use Schedules.
Best answer by hkingsbury
FME uses the Quartz Scheduler which has slightly different syntax to other CRON based systems.
The expression you’ll need to use is:
0 0 0 1 3,6,9,12 ? *
This is a helpful site for testing and building CRON expressions for FMEhttps://www.freeformatter.com/cron-expression-generator-quartz.html
Thank you! It accepted that expression without error!!
14 votes
13 votes
12 votes
10 votes
9 votes
4 votes
3 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
