Exporting the project is not permitted. Items that don't exist or are inaccessible by you
sam_appleton
Forum|alt.badge.img+7
Hi All,
I get the following error when trying to export a project where there is an issue with a dependency:
This project contains items that don't exist or are inaccessible by you.
My user is a superuser and I can see the file however when I click the link to take me to the file, I can see that the link is different. Is there a problem with the link?
Link returned by project:
/fmeserver/resources/lookup?path=FME_SHAREDRESOURCE_DATA%5CEDM_CSV
expected link:
/fmeserver/resources/browse?path=FME_SHAREDRESOURCE_DATA%2FEDM_CSV&name=Data
I noticed that @kate-safe mentioned in a recent ticket that this was a known bug (
Is there anyway to fix this without upgrading FME flow? It’s put a halt on all of our deployments.
Flow installation details:
FME Flow 2023.1
Build 23619 - win64
Many thanks!
Sam
Best answer by siennaatsafe
Hi @sam_appleton
There is a workaround. The workaround to this is to either run the workspace with the Job Submitter service first to ensure the resource path is created before creating the project.  Another option is to have the default path point to an existing data resource folder.
However, there isn’t a patch. If you’d like a permanent solution you’ll have to upgrade.
siennaatsafe
Forum|alt.badge.img+11
  • August 21, 2024
Hi @sam_appleton
sam_appleton
  • August 22, 2024
Thanks @siennaatsafe the default values were set to this:
:$(FME_SHAREDRESOURCE_DATA)\EDM_CSV
Changing the value to forward slashes and re-running the workbenches has fixed the issue:
:$(FME_SHAREDRESOURCE_DATA)/EDM_CSV
Thanks for your help :D
