FME server: Some or all of the input parameters are invalid
  • August 19, 2024
  • 34 views
vanessarapior
Hello :) I get this message on FME Server 2022 and I do not know what is wrong.
j.botterill
Forum|alt.badge.img+40
  • August 19, 2024
My guess, and it’s only a guess without seeing logs or the fmw itself, is you have a defined one of your input parameters in Desktop/Form with a User Parameter type, which there are many:
Then in Server/Flow you have an input that doesn’t meet the parameter type configuration. For example if use the Number parameter type, set the configuration to between 1 and 99…. I cannot entered 100 in the Flow interface
