Building Areas bounding endpoint vertex from lines
  • July 16, 2024
  • 34 views
armando_amador
Hi all,
I have a set of input street lines with certain attribute (POSTAL CODES), and I would like to create area polygons from unique values of such postal code attribute.
Street Lines with postal code attribute
I have utilized AreaBuilder for such purposes and this is an example of the output:
Inner polygons created by AreaBuilder
This is the params I have for such transformation:
What I would like to have as an output is the area covered by all the street lines with unique postal codes, something more like this:
Desirable Polygon from street lines
Is there any other param customization I have missed or something else to do about?
Regards.
Best answer by liamfez
Based on the example/desired output image, you may be looking for the HullAccumulator or HullReplacer.
liamfez
Forum|alt.badge.img+35
  • July 16, 2024
