I have a deployment parameter (Text) that is pointing to an SDE file on FME flow in my shared resources. When I try to set a local value in form, it ignores this value and throws an error saying it can’t access the share resources file path. I’ve tried creating a deployment parameter that is type: database connection, but this doesn’t work either. Here’s the error:
This was working a week ago and now it refuses to acknowledge the local value.
Many thanks,
Sam
