Change Detector Python Caller for GIS FC and API
  • July 2, 2024
  • 40 views
boomer87
Curious if I could pick your brains on how to achieve the workflow:
I am connecting to an asset via API as well as another separate GIS Feature Class in an EGDB.
The workflow will start with a user editing the GIS Feature Class. When a user updates or creates a new record in the GRI_TEST1 Feature Class, I am pulling it into the Change Detector, and wanting to write to the API table only if the assetkey does not exist in the API table. The assetkey in the GIS FC = unitid in the API Table, as the field has a different name than the same column has in the GRI_TEST1 Feature class.
Would I be going the right route here in using the PythonCaller to achieve this? Right now my writer is writing to a xlsx document and not the API table yet so I could test out the logic.
# Import necessary modules
from fmeobjects import *
# Function to check if asset key exists in feature class
def assetkey exists(assetkey, feature_class):
    # Implement the logic to query the GIS feature class
    # Assume 'feature_class' is an object representing your GIS feature class
    # 'assetkey' is the ID of the asset you're checking
    # Example logic (replace with actual GIS query)
    for feature in GRI_TEST1:
        if feature.getAttribute('ASSETKEY') == assetkey:
            return True
    return False
# Initialize FME features and parameters
def main():
    # Initialize FME objects
    feature = FMEFeature()
    # Get asset ID from input feature
    assetkey = feature.getAttribute('ASSETKEY')
    # Example feature class - replace with actual feature class access
    feature_class = FMEFeature()
    # Check if asset ID already exists in the feature class
    if not assetkey_exists(assetkey, feature_class):
        # Asset key doesn't exist, write the record to the feature class
        feature_class.write(feature)
# Call the main function
main()
Would that be the correct idea? What about in cases where a user deletes a record in the GIS FC - would that be a separate python caller to handle the deletion cases?
Thanks so much.
evieatsafe
  • July 4, 2024
Hi @boomer87 sounds like you might be able to achieve the same outcome with some conditional values and an AttributeManager. And depending on what your output is from your API call (JSON or XML) you can also use the relevant transformers to parse this information as well e.g. JSONFlattener, XMLFragmenter, etc.
Here’s a tutorial to get you started:
Although you can still stick with the Python route, you can also use the no-code solution in FME to produce the same results. Let us know if you have any specific questions!
