Cut the fme polygon from fme aggregate
ienesaglam60
How ı Cut the fme polygon from fme aggregate?
You can find the photo attached
turquoise color object is fme aggregate .
purple colored object is fme polygon .
I want to cut below the yellow line.
saraatsafe
Forum|alt.badge.img+9
  • June 10, 2024
Hi @ienesaglam60, you could try exposing the fme_geometry attribute using an AttributeExposer, and then using a Tester to filter out the fme_polygon attributes. Please see the attached .fmwt for an example of this!
Alternatively, if you have anything you can clip this to, you could also try using the Clipper which can clip aggregates.
Please let me know if you have any questions!
danilo_fme
Forum|alt.badge.img+45
  • June 10, 2024
saraatsafe wrote:
Hi @ienesaglam60, you could also try exposing the fme_geometry attribute using an AttributeExposer, and then using a Tester to filter out the fme_polygon attributes. Please see the attached .fmwt for an example of this!
Great solution!
