Fill gaps in time series data?
jacklonsdale
Hi all,
I have a 15 minute timestep data which has random missing values (expected). I’ve managed to track where the data has gaps, but in order to calculate a consistent rolling 24 average of the value I need to fill these missing gaps with a timestep but null value (so i can calculate an average from the preceding X values)
Does anyone have any suggestions on how to fill these data gaps automatically? Or better still calculate a 24 hour rolling average using specific timesteps rather than just number of rows?
Best answer by geomancer
You can create all the timestamps you should have, and merge these with your actual data stream to get a continuous series of timestamps.
geomancer
Forum|alt.badge.img+48
  • May 13, 2024
jacklonsdale
  • May 13, 2024
Thank you this worked perfectly
geomancer
  • May 13, 2024
You're welcome!
