change coordinate format DM -> DD
  • April 25, 2024
  • 37 views
alfons
Forum|alt.badge.img+7
I'm sure it's a pretty simple question, but somehow I can't see the wood for the trees to find the answer.
I have a list (.xls) of coordinates in the form <name>, <x_coord>, <y_coord>. The coordinates are, for example, in the form N 51° 06.796 E 3° 14.545.
Now I want to save the information in an FGDB and would have expected the VertexCreator to help me with this. Unfortunately, all my values are completely rejected. My further attempts - removing all spaces; using the HUB Transformer "DegreeFormatter" or Decimal Degrees Calculator all failed. For this reason, how do I manage to get the coordinate format into a form so that the VertexCreator accepts it? Thank you very much.
virtualcitymatt
Forum|alt.badge.img+39
So the required format and inputs for the DegreeFormatter are as follows
DD°MM.MMM’ (E|W|S|N)
So your x (long) would be  3°14.545’ E
and the y (lat) would be 51°06.796’ N
Combined it should be:
51°06.796' N, 3°14.545'E
I’m not sure at the fastest way to do this but I would probably try the following
Extract the direction from coordinates using a couple of SubstringExtractors (just get index 0). save these as an attribute called “_direction_x” and “_direction_y” or something
then use a StringReplacer to remove all the <space> charachters and letters - regex = [a-zA-Z]|\s
Then after that you can use an AttributeCreator/manager to make new combined x, y values which you can feed into the DegreeFormatter.
@Value(y)' @Value(_dicrection_y), @Value(x)'@Value(_dicrection_x)
This should give you an attribute with the value 51°06.796' N, 3°14.545'E which you can feed into the DregeeFormatter.
