How to call quick translator using batch file?
  • March 20, 2024
  • 46 views
saravanakumar
Hi all,
I want to run a workbench in quick translator mode instead of running whole workbench using .bat file
j.botterill
Forum|alt.badge.img+40
  • March 20, 2024
Whilst I’m not sure about the Quick translator, perhaps you can try to run the fmw workspace in Workbench (form), and refer to the top of the translation log. There are the commands you can copy to a .bat file on how to run the process via command line.
Here is some documentation regarding command files: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/Working_with_Command_Files.htm
