Connect point to line perpendicular
checcosisani
Forum|alt.badge.img+12
Hi
how can create a perpendicular line that connect point to line, I mean I need to connect red points to blue line with a perpendicluar line
thx
Francesco
One way to do this:
  • NeighborFinder
    • Points are bases
    • Lines are candidates
    • Number to match = 1
  • VertexCreator
    • Add Point
    • _closest_candidate_x
    • _closest_candidate_y
redgeographics
Forum|alt.badge.img+50
The NeighborFinder will return the coordinates on the candidate (line) that are at the closest to the base (point), so you can then construct the perpendicular line (VertexCreator and the _closest_candidate_x and _closest_candidate_y attributes)
