Comparing two dates types
  • March 11, 2024
  • 80 views
fbrenn
Hello!
Here is my problem:
I have a SDE db (let’s call it T1) with field “date_change” (type: date). I also have a table (let’s call it T2) that has a filed “sync_date” (type: date).
I am trying to make a query where I select all features from T1 where “date_change” is equal or greater than T2 “sync_date”.
I am using a FeatureReader and trying to apply it on the where clause. However, my query keeps coming blank. I think the syntax is wrong (WHERE clause: “date_change” >= “sync_date”).
Anyone has any suggestions?
Thank you in advance!
Best answer by nielsgerrits
You probably have to reformat the date. FME reads date as %Y%m%d%H%M%S where SDE might be expecting something like %Y-%m-%.
See this topic:
  • March 11, 2024
See this topic:
