Add AD User Name into FME Flow
  • February 21, 2024
  • 147 views
vxn43
Forum|alt.badge.img+18
I am using FME Flow 2021.
Is there a way to add Active Directory User Names and credentials into FME Flow? Sort of like SSL/SSO with ArcGIS Enterprise.
My goal would be to be able to use the same user credentials I use on our network for logging into FME Flow.
Currently, my FME Flow has a domain user name, but the user names in FME Flow are built in.
Best answer by thaverkort
Yes!  I have a slightly older version, but in my instance, it in the FME Flow web interface under Authentication Services.  Add your domain controller URL to the Windows Active Directory tab.
thaverkort
  • February 21, 2024
