Question of the Week: What advice would you give a new FME user just starting out?
  • July 29, 2025
  • 28 replies
  • 613 views
Show first post
arcvancouver
Forum|alt.badge.img+19
  • August 14, 2025
Two things that I always say as part of the trainings I run are:
  • Just try it, don’t ask ‘do you think this will work?’. Implement the logic, and understand what it’s doing. It might work, it might not, either way you’ve learnt something!
  • Give a problem to a room of FME users, and they’ll all come up with a different solution. Each will have its own advantages, and disadvantages. There’s not one ‘right’ solution. They’re all dependent on the circumstances around the problem. You may find solution A works well in this case. You’ll then have a similar, but slightly different problem, and solution B works better than solution A.
With respect to the latter point, there’s a practice called CODE GOLF: a type of recreational computer programming competition in which participants strive to achieve the shortest possible source code that solves a certain problem.” (thanks Wikipedia)
I feel like once you start getting comfortable with FME workbenches, try FME GOLF: shrink your workspace into the minimal amount of transformers that runs the fastest. Sometimes it’s as easy as throwing an Attribute Manager in the mix, or learning how to use SQL WHERE statements in your feature readers ;)
hkingsbury
Forum|alt.badge.img+70
  • August 14, 2025
I do like that concept, and often aim for that myself.
Like a lot of things, I do find the context of the end process to determine to what extent I build with that in mind.
If I was building an internal process that was going to be maintained by myself or colleague (we’re resellers of FME) I would use more advanced techniques that will make the process more efficient, smaller etc.
However if the process was being delivered to a client where FME was a tool they used to help achieve other outcomes, I may not utilise some of the more advanced functionalities to ensure the process is easy for them to maintain and manage going forward. Of course, situations like this are valuable learning opportunities so I try to gauge whats appropriate for the client.
A couple of good examples are:
  • WHERE clauses and spatial filtering on (feature)readers - A lot of beginner users may not realise or understand the advantages of this approach
  • SQL Joins - I’m not an SQL expert, but can work my way around a join. Whilst is may be more effcient to use an SQLExecutor to join some tables and then read the data, it may be easier for the end user to maintain a process that uses (feature)readers and a FeatureMerger/Joiner
marcust
Forum|alt.badge.img+20
  • August 14, 2025
Sign up for the free training and don’t be afraid to try things or ask questions
