Child workspace is using a published parameter (integer) in a RasterExpressionEvaluator.
The parameter is sent from a WorkspaceRunner.
Translation fails with a fatal error. From log:"
2021-11-07 13:01:35|  0.5| 0.0|ERROR |RasterExpressionEvaluator_3 (RasterEvaluationFactory): Failed to parse the EXPRESSION_LIST clause. 'A[0]' was successfully parsed, but '-/10' could not be parsed. Please ensure that your syntax is correct"
The evaluated expression was supposed to be: A[0]- $parameter/10, but is left blank.
Try using a ParameterFetcher to fetch the published parameter into an attribute and then use the attribute instead.
Thank you - although it feels a bit like duct-taping a brand new Porsche it does the trick.
I've got a feeling this is a known issue that has recently been fixed.
