Workspace doesn't use parameter
  • Nov 7, 2021 12:05 PM UTC
  • 85 views
mathiku
Forum|alt.badge.img+8
Child workspace is using a published parameter (integer) in a RasterExpressionEvaluator.
The parameter is sent from a WorkspaceRunner.
Translation fails with a fatal error. From log:"
2021-11-07 13:01:35|  0.5| 0.0|ERROR |RasterExpressionEvaluator_3 (RasterEvaluationFactory): Failed to parse the EXPRESSION_LIST clause. 'A[0]' was successfully parsed, but '-/10' could not be parsed. Please ensure that your syntax is correct"
The evaluated expression was supposed to be: A[0]- $parameter/10, but is left blank.
Best answer by gazza
Try using a ParameterFetcher to fetch the published parameter into an attribute and then use the attribute instead.
gazza
  • Nov 7, 2021 11:49 PM UTC
mathiku
  • Nov 8, 2021 10:18 AM UTC
Thank you - although it feels a bit like duct-taping a brand new Porsche it does the trick.
gazza
  • Nov 8, 2021 7:16 PM UTC
I've got a feeling this is a known issue that has recently been fixed.
