Why HTTPCaller replaces Ñ by %D1 instead %C3%91 in Query String Parameters?
Best answer by takashi
Hi @j4, as you say, I believe Ñ should be encoded to %C3%91, rather than %D1. It could be a defect of the HTTPCaller. Hope someone from Safe will check this.
As a workaround in the interim, as @david_r mentioned, you can use the TextEncoder to encode the parameters and then construct desired URL string containing the parameters, in the URL parameter field.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
