Why HTTPCaller replaces Ñ by %D1 instead %C3%91 in Query String Parameters?
  • October 20, 2017
  • 53 views
jorge_rosales
Forum|alt.badge.img+8
Best answer by takashi
Hi @j4, as you say, I believe Ñ should be encoded to %C3%91, rather than %D1. It could be a defect of the HTTPCaller. Hope someone from Safe will check this.
As a workaround in the interim, as @david_r mentioned, you can use the TextEncoder to encode the parameters and then construct desired URL string containing the parameters, in the URL parameter field.
  • October 20, 2017
URLs with parameters containing special characters (including spaces) needs to be encoded using so-called percent encoding and I suspect the HTTPCaller tries to do it for you.
You can also encode the parameter values manually using the TextEncoder transformer, that way you'll have more control over the final URL.
  • October 20, 2017
jorge_rosales
  • October 20, 2017
I did it. TexEncoder changes 'BREÑA BAJA' by 'BRE%C3%91A%20BAJA' but HTTPCaller changes 'BRE%C3%91A%20BAJA' by 'BRE%25C3%2591A%2520BAJA' (% -> %25). So I discarded using Query String Parameters and constructed the full url manually (StringConcatenator) as @takashi mentioned. What is odd is that HTTPCaller works fine with an url including Ñ character.
