Whats your workflow to run jobs locally (FME Flow debugging)?
  • Sep 25, 2025 6:40 AM UTC
  • 6 replies
  • 122 views
itsmatt
Forum|alt.badge.img+48
Just wondering what kinds of workflows do you all use to try to reproduce an issue in a workspace which was run on FME Server.
I have some workspaces which have quite a few parameters and copy and pasting the parameters from FME Flow to FME Form is getting pretty old…
Any clever workflows people have developed to set parameters automatically from a job?
I’m thinking of putting together a tool/workspace to try auto populate parameters from a job but I wanted to see if I was just being dumb.
I’ve been using presets to save time for a lot of the parameters which tend to stay the same, however, it I’m not careful I end up missing something and speeding time wondering what my results in Desktop and Server are different because I missed something small in the parameters
birgit
Forum|alt.badge.img+25
  • Sep 25, 2025 7:12 AM UTC
We often have a lot of parameters which are project specific. I.e we have project A with 10 parameters that are basically static and project b with 10 parameters that are also basically static. What we do is save the "parameter” values to our database and just use 1 main parameter in the workbench that says to get project A. Then use the featurereader to get all the needed settings as attributes instead of parameters. Its much less error prone but it only works if you for example know that for project A you always want to read a specific folder (or folders).
itsmatt
  • Sep 25, 2025 7:25 AM UTC
OK  - I’m going to do some workspace hacking. Let see how I get on
itsmatt
  • Sep 26, 2025 10:27 AM UTC
Well I made some good progress but didn’t save my workspace - Workbench crashed and I lost it all - dang. But it was very hacky and most likely would not really have worked for most many workspaces.
Maybe I’ll have another go when I get really frustrated
nielsgerrits
Forum|alt.badge.img+67
Is this about user parameters? From a form? Or environment parameters?
itsmatt
  • Sep 26, 2025 11:32 AM UTC
Yeah I just want to run a workspace in FME Form with the same inputs are from the job FME Server. It’s easy enough to copy paste but if there are a lot it gets annoying.
Essentially I have a workspace in the middle of an automation that I want to run locally (it has ~10 parameters which need to be set). The outputs from the automation writer from a previous job are used to populate the workspace.
I’ve developed the workspace against a wide range of test data, however, now I’m in beta testing and there is a lot more real world data (and user setting combinations) which are not getting handled properly.
nielsgerrits
Clear. Sorry, we don’t have anything built for that scenario.
